a4LD to manual issues...No spark?
90B24wd
Big Island Hawaii
Try connecting a code reader and see if you are able to get any codes. If you don't get any codes then you would know it could be your wiring or ignition?
Had a problem while replacing the heads on my new Bronco II. It would crank but not start. I connected a code reader to check for codes and I didn't get a blink (no clicking noise also). The only other thing that I had done was to replace the stator in the distributor (module tested OK). Replaced the distributor with another distributor with used module and stator and it started right up.
raiper
BII
ill try the code reader again gotta remember how this one works.....My B2 has the 4.0 EFI no distributor
