damone
- Dec 27, 2017
- 10
- 1985
85 2.8l
Previous owner told me clutch was bad. replaced with junkyard clutch and still cycles. Is this a sign or bad clutch?
Is there a way to check to see if the clutch is good/bad?
Can you add 134 to R12?
How can you tell if you have R12 bs 134?
Clutch cycles and when trying to add fluid the pressure raises until the clutch cycles and it falls to correct reading in gauge right when clutch cycles off (1 sec.). Do you think some fluid is getting in when the clutch cycles. Maybe eventually enough will get in keep cluctch engaged?
Will the system take fluid w/o the clutch engaged?
