alterations for a 302
fpriessnitz
1987 bronco II
when i put in a 302 v8 in an 87' ford bronco II what are my main concerns to alter under the hood? in other words what big changes will have to made to acquire the larger engine? i guess wheel wells and anything else ect. just trying to get all the info i can. thanks.
red85
Kitchener, Ontario, CANADA
306 ci
check out the tech pages for the run down on this. Welcome!
superdave1984
South Fulton, TN
I didn't have to do anything except dent the driver's floorboard near the bottom of the firewall to clear the headers. Used headers for a 72 mustang with no issues other than that.
baddad457
Opelousas La.
Ranger
Wheel wells need nothing, the heater-A/C box needs to be clearanced to clear the right side valve cover. Your main concern is the longer engine, the width is a non issue, except for the A/C box.
projectnitemare
Osceola Mills, Pa
396W
Exactly, width isn't the problem. The heater box is a definite. If you are pretty good you can cut the chunk out, flip it around and plastic weld it back in. I'm good with fiberglass, I used that instead. There is a seam in the trans tunnel that sometimes needs to be pounded over. It's not a bad idea to put the radiator under the core support for extra room.
Matt
