Anyone ever used Sea Foam?
sweetwaterbroncoII
Sweetwater, TN
I went to the local parts store the other day and picked up a can of Sea Foam....I put it through the engine the way the parts guy said....not through the fuel tank...He told me it would smoke like heck and spit and sputter for a few mins, but the end results would be amazing....I have to agree...maybe its my wishful thinking, but the little 2.9 ran alot better, smoother, and quieter afterwards....Has anyone else tried it?
sweetwaterbroncoII
Sweetwater, TN
Man I mean I am EXTREMELY impressed with this stuff! I can't say enough about it! I wonder how often you can use it?
clevemech
Cleveland, OH
Ranger
2.5L
Sea foam I call it e-check in a can! Gives what I call the smoke show just awesome
Wicked_Sludge
Westport, WA
3-point-GO
seafoam can do wonders for an old carboned-up engine. it really makes a difference.
you dont need to run it very often if you dont drive like a grandma (my engines all see 4 grand at least once a day to keep the carbon down). i run it maybe once a year if i think about it.
it does a pretty good job when run through the fuel tnak too :icon_thumby:
sweetwaterbroncoII
Sweetwater, TN
I had never heard of sea foam until a few weeks ago, I am glad I tried it....my BII is running alot better with it!
1988broncoll
South jersey
Ive heard about seafoam like maybe 2 weeks ago and i watched a couple of videos on youtube of people using it. But I wasnt sure if id trust it or not the more I read up on it the more I think about trying it. From what ive seen when you use it the motor smokes like a SOB how long does that last for? what way would yous recommend doing it through the fuel take or just doing it through the intake?
Wicked_Sludge
Westport, WA
3-point-GO
i do it through both.
the smoke lasts a few minutes.
sweetwaterbroncoII
Sweetwater, TN
I would do it through the intake....It smokes pretty bad while you are actually doing it, but after you let the engine sit for about 5 minutes, and you re-start it, the smoke only last for around 15 mins or so.....But trust me, you can reallt tell a difference immediately! you will be impressed.
therieldeal
Putnam, CT
i usually put 1/3 of the can in the oil the day before my oil change. i run 1/3 through the intake right before i change the oil. then i dump the last 1/3 in the gas tank.
azhrei
Allenstown NH
ok so in the old carb days we use to pour a quart of mystery oil in, talk about smoke! I wonder how similar it is? I still throw it into the gas every now and again... haven't figured out how to put it in now thru the tbi!
gearjmr
Hoquiam,Wa
Seafoam
I was first told about Seafoam from a guy who fishes commercially in Alaska. He dumps it in his fuel to disperse water and help kelp from jelling up.
I disconnect my vacuum linr from my brake booster and slowly pour about half a can in, shut down and wait 5 mins or so. The other half in the tank. This is definately a "do outdoors" show...
1988broncoll
South jersey
aww damn i wanted to do it in my 2 car garage with the doors shut and the heaters on to stay warm JUST PLAYING. i couldnt resist
240cubes
'00 '96 '89 '88
i always put about 2/3 of the can through one of the vaccum lines, usually for the brakes. never been dissapointed.
Southern_Trendkill
U.S. Military - Active
Jacksonville, FL
Mercury, Mitsub
144 "Thriftpower", 2.4 MIVEC
Is there any performance to be gained by putting it in an engine that runs fine? I'd like to make sure the system is clean, but I've heard that older engines can lose compression, and so I want to make sure it's worth the risk.
Wicked_Sludge
Westport, WA
3-point-GO
if you have carbon build up inside your motor and run seafoam through it it can lower your compression because it removes the carbon.
Sidewalk
Jamul, CA
Never used it.
But I seemed to have the best running BII out of anyone I knew. It always ran perfect, and got better fuel mileage then anyone else. Why add some crazy chemical when just normal maintenance of changing the oil, putting in gasoline, and driving was all it needed?
You could save money by misting water down the intake too. Instant steam cleaning of the combustion chamber.
How much do you think he would have to use in a 4000 gallon fuel tank?
Normally on my ship, if there was water in the tanks, we stripped them (hand pump suction from the bottom to remove water). They are designed that way on purpose. Of course, the water seperators on every filter help.
But then again, since oil and water don't mix, dispersing it would actually just make the problem worse.
jaymegriffiths
Regina,Saskatchewan
How exactly did you run this seafoam stuff through your engine? Is there any negative effects? Where can it be purchased?(I live in canada)
jaymegriffiths
Regina,Saskatchewan
Is this a bad thing? i don't want to take any chances on damaging my engine, but since i got it it has gotten progressively worse at starting. maybe this can improve it.:icon_confused:
Wicked_Sludge
Westport, WA
3-point-GO
under most cases the change isnt big enough that you would notice. its enough that if your having spark knock problems, it could reduce or eliminate them.
