The same 4x4 module is used in the Explorer up to 1995.They're locatated in the left rear cargo panel. The Bronco2s 8 wire plug that plugs into the module gets brittle and the wires will pull out and shut the 4x4 system off. I just filled the top portion of the plug head with silicone to keep the wires in place and haven't had a problem since.
Thanks for the help! I checked the plugs and they looked good. I don't think it is the plugs because the 4x4 doesn't ever shut completely off it just doesn't get the signal the the shift motor and transfer case is in 4 wheel so it takes it back into 2 wheel. It inly does this sometimes.
