hey guys, i'm new to the forum but i just picked up an '88 bronco II, 5 speed with 4x4. its completely stock and except for one problem, runs great. it will crank and run fine while its cold, but when it heats up and you try to accelerate, it will try to die and cut off. if your cruising it will do fine and i drove it 50 miles home, shut it off and it cranked right back up. when i was going down the rode, it started sputtering a lot worse and it just died. i turned the key and you can't hear the pump come on until you let it cool off. i suspected the ignition module, but the previous owner said it was only getting 6 volts to the pump that is on the frame rail, but he didn't know why. any help would be greatly appreciated because i'm ready to get it on the road with no worries. thanks!
