I think where I messed up is not putting the bracket back on the inside (the metal piece that came off the old one in your pic above) - I used 2 large washers on each side...I'm wondering if it would just slide over now.
It works and works well - had to modify the tire carrier repair someone did on it before I bought it to get the handle on but the drill bit I had made two nice round holes and I slid it right in (had to enlarge the middle one just a tad).
I'll get some paint (desert tan and sand off that metal and clean it up)...
trying to decide if I need to put that metal bracket on the inside of the door or not - think the washers are good enough?
Also, I've got to fix the door lock now - it's never worked (turn the handle and it unlocks it) but unless the key part is wore out I can't figure out why it doesn't work - played with it for half an hour trying to figure it out. Another project for another day...gotta research it...
