jaredm_k
- Jun 3, 2013
- 5
- 1977
I just bought a 1985 Bronco II, been sitting for a long while so there is a lot to go through before I can have a reliable vehicle. The biggest problem I am running into right now is that when I press the clutch pedal - the brake pedal also depresses slightly. Then when you release the clutch, it does not come all the way back up and you actually have to put your foot behind the pedal and pull it the rest of the way up, same with the brake. I was looking for a diagram of the pedal assembly but no luck so far. If anybody has advice for me I am open to it! I'm not sure if there should be a clutch return spring or something, and even if there is that still probably doesn't solve the brake pedal. But I would assume the two problems are connected. Thanks for your help!
