- May 13, 2010
- 157
- Sulphur Springs, Tx.
- 88,89,07
Hey guys I posted this just to try to help somebody avoid the nightmare that I am currently facing. i just done a 4.0 swap in a 89 BII and used a 91 Explorer dash and harness. This was done simply because i am changing the interior color to that of the Explorer. It bolted in and most plugs plugged right up except for the electric transfer case wiring which I dont need anyhow. After getting everything hooked up I installed the battery and viola it started right up. However the rear lights(all of them),fuel gauge,turn signals and 4 way flashers don't work. After doing a little research, which i should have done prior, I found out that the Explorer sends the rear lighting out through a plug under the dash where the BII and Ranger send it through the firewall at the BWP and to the light wiring on the drivers fender well. There may be more that isn,t compatable that i haven't figured out yet. Looks like I will have to change the wiring harness for the dash out with the original BII harness, PITA!!
Hope this helps someone!!
Paul
Paul
