Durasprk questions
Lifted2x
Medford, OR
I have a 84 bronco 2 that i started doing the duraspark conversion on and i got everything in and it will start and run but i cant get get it to idle i am using a 2150 carb with the 1.08 venturis but it is off a bigger engine. It will run good at hight rpms but it just dies at lower revs unless you constantly feather the gas. I just used a holly style gasket thats not quit the same as the carb base. do i need the specific gasket? and my other question is where is the correct port for the vacuum advance for the dist.? Thanks for any help
