Explorer Spring Question
Plummkrazy
Seattle
Hey guys,
I have been looking around and haven't really found the answer. I am planning on doing the explorer spring lift to get a little lift on my B2, but what about the shocks? Do they need to be longer or is there enough travel on the stock ones?
Thanks!
Phantom
Salida CA
I think there is threaded shock extenders that thread on to the shock and extends the threads for the mount with that type of lift... Haven't used this first hand..
Iceman21
Brewster, WA
Bronco 2
2.8L (soon to be 350) and 2.9L
I installed the 1st gen explorer springs on my 87 b2 and it gave me aprroxitmtely 3.5" of lift. This was six months go and as far I can tell they have plenty of length in them, even with the greatly improved flex you can achieve with them(in the rear)
Plummkrazy
Seattle
that's cool, thanks for the info. Yeah I am looking forward to a little bit of lift and firmer ride. My stock springs are pretty saggy and shot.
Jeff
Surrey
Vancouver, Canada
Your stock springs must have been in really bad shape to get that much lift outta explorer springs...
Typically they only get you 1-2 inches.
Your stock shocks should be fine with that small of a change, but you could probably get something a tad longer from a wrecker while your getting the springs - really your choice.
Plummkrazy
Seattle
I plan on buying new shocks, so I didn't know if I should get the ones for an Explorer or what? ones setup for a B2 with 2" lift maybe?
Thanks
mechanicsrule1
Springfield, mo
rear shocks
You can go to oreillys and they (for sure ive done this) have a book showing the type of shock and differences in length so if you got a 3 inch lift you just need to find a shock to match.
Plummkrazy
Seattle
oh great thanks. Yeah i was actually looking on Summit racing and you can look by amount of lift. They have Sky Jacker and SuperLift shocks.
Plummkrazy
Seattle
thanks for all the info, i am on Summit ordering some parts now.
88_Eddie
Raleigh, NC
broncograveyard also sells shocks for a 1-2" lift
