f-250 shock mount on bronco 11
snapmac
Diego Baby
2.9 going to be 4.0 soon!
I'am Going To Install The F-250 Front Shocks Mount On My 1988
Bronco 11 Does Anyone Remember What Series Number Rancho Shock
Or Other Shock Number Will Work. My Bronco 11 Has A 6" Skyjacker
Lift With Long Radiaus Arms And Do I Need To Go To A Longer Coil
Spring.
CopyKat
Manitoba, Coldest place in Canada
Just look around. It would be the same setup that the ranger guys would go with. I know there are a couple guys that have them installed.
As for shocks, you going to have to measure them. It depends on the amount of suspension travel you have.
snapmac
Diego Baby
thanks for the reply i was just trying to get out of doing the extra leg work
BDAB
Southbend IN
Ford, Ford, Bui
V10, 5.4L, 3.8L v6
If you can't go through it or around it, then go over it.
whats a Bronco eleven?
cobra18
Whoa, just what I've been looking for. I'm not new to the game but I am new to Broncos. I want to do an F-250 suspension swap. Seems fairly cheap and easy. I know there would be cutting and welding for rear spring swaps but as for the front. What do I need and what's involved. I'm an aircraft mechanic by trade so I'm a capable wrench turner but just starting to teach myself cutting, welding, and fabbing. But I'm always down to try new things. Any help is greatly appreciated guys and gals.
87xjmike
Shot with DSC-T1 at 2009-06-30
Shot with DSC-T1 at 2009-07-06
Just did it in mine. Real easy. Used and arc welder to cut the coil buckets and welded the shock mounts to the buckets to keep the integrity of the buckets. I think the shocks were 12" travel with 6"s of lift. they are perfect attached to the eb radius arms, not sure about the b2 arms. they were 15 each from the ford dealer.
