The issue is the fan doesn't seem to have enough pulling power at idle. Even with the new fan clutch installed, damn thing is loud but doesn't seem to be pulling much at idle, engine temp climbs pretty high too.
I will try the foam tape too but like you it'll probably give the same results. How on earth did the AC work so well before LOL. Oh yeah, R12 worked better and ran at much lower pressures than the R134a.
How does your AC work out on the highway? Mine works awesome on the highway, I can run the fan speed on low once the cab cools down. Around town when moving its not bad at all but sit at idle for a few minutes and the vent temps start climbing pretty quick, start moving again and it cools right back down.
I wasn't having engine temp issues, but the radiator is pretty new, although only single row. Tonight the engine couldn't really warm up, I could tell by the gauge the t-stat was just barely opening. Full open is just under mid-gauge on mine and it was running at quarter. Even with AC going full blast so it was pulling hot air from the condenser through radiator. The foam trick seemed to help there.
My 86 we had back in the late 80's and early 90's was very "meh" as far AC went. We lived in the Phx area and it just didn't do a good job, but that's Phx... That was factory AC with R-12 in it. When we lived in TX it was "ok".
Mine doesn't seem to get any better over about 25 mph, that's pre-foam. But it's pretty good at 25mph. The other day I was driving around with the fan on the middle speed and it got down to 39 at the vent.
I'm ok with AC that is "ok", but I don't want super high pressures that are going to kill the compressor. It's cooling well enough for me, now I want the compressor and other parts to live a long time. Hopefully tomorrow it will be hot enough that I can tell if sealing up the air gaps helped or not.
Thanks to all of you guys helping me with this, I appreciate it.
