el burro
- Aug 4, 2011
- 18
- salem,OR
- 1986
- 2.9
Hey guys! Quick question... I just did a chevy 63 swap on my bronco ii and it doesnt flex nearly as good as it use to with the stock style springs and the stock shackle arrangement... So this leaves me to wonder if its because of the shackle being to far verticle? Because i jacked one side of the truck to test down travel, and it was quite sad. I lost alot of flex. But what I did notice is that the shackle doesnt move. I seen pictures online and it looks like with the flipped shackle arrangement, the shackle is suppose to fully sag and then the spring will do the work. Mine does no such thing. But i think it could be because ot the angle of the shackle.. right now its 90 degrees, maybe even 100 degrees. And from what i hear it should be 45 degrees pointed towards the front or the truck. What are your guys thoughts? Cause i want to get the most flex as i can out of this setup. And i know it should flex much better than the stock style setup, right?? Thanks!
