projectAtoB
- Aug 9, 2007
- 8
- Age
- 40
- 1989
- ford
ok so first off the starter hung on my 86 bronco II. its nothing but a 400 dollar play toy, so for a couple of days i simply took the starter wire off of the starter solenoid and was toching the wire to the post when i wanted to start it. i know thats stupid and not good for anything but its a 400 dollar truck so spare me. anyways someone else tried to start the truck and touched the starter wire to the wrong post of the starter solenoid. it burnt alot of fuses, screwed the starter solenoid, the batery, and the fuel relay i replaced the battery it was under waranty new solenoid and fixed blown fuseable links. and fuel pump relay. now first off i noticed the pump wasnt coming on when i turned the key on. that was first prob. there are 4 wires on the relay a power wire coming from the starter solenoid, wire going to the inertia switch(which has already been cut out) and a smaller gauge wire and a red wire. i can apply 12 volts to the wire going to the inertia switch and the pump cuts on. but the smaller wire which i am guessing its the trigger wire for the solenoid has no power on it( I know its momentary when u cut the switch on) so i was going to put a switch on the pump to cut it on(remember its a beater truck) i wanted to make sure it was gonna work so i applied 12 volts to the relay again cut the pumps on and tried to crank it. thats when i realized i had no spark. very long story short, is this pointing towards the computer is bad? very sorry about the long post im just stumped here.
