Fuel Gauge opposite issue
89XLT
This thing is pegged at Full. New sending unit..... Any ideas? Next I have zero wipers...... just starting down that rabbit hole....
Did your turn signals just quit or have they never worked?
89XLT
Turn signals work perfectly.
89XLT
They haven’t worked. I have power at the fuse block. Not after the switch in the engine bay.
When you push the washer, does it work? Both washer and wipers are part of the multi switch in the column.
89XLT
No. Neither functions at all.
89XLT
Will do. Thank you. Any thoughts on the fuel gauge?
Did you put the new sending unit in because it alway registers full or did the problem come after the new sending unit?
89XLT
It’s after the new unit was installed. Before it was registering empty.
I would suspect the new sender is the wrong one. Pre 89 low ohms was full tank. 89 changed to high ohms full. If you can take the connector off the tank and put a ground on the yellow wire it should make the gauge go to empty or even past empty. The yellow wire is the ground to the fuel gauge.
89XLT
Genius! I’ll try that tomorrow! Thank you!!
