Fuel injector cleaner/Gas treatment
sweetwaterbroncoII
Sweetwater, TN
Does anyone use fuel injector cleaner or gas treatment? If so, which brands are best?
racinranger
tuckerton NJ
yea seafoam, half can in the tank and a half can through the vacuum lines. If its super nasty and scary. I'd go with a whole can in the tank and a whole can sucked into the intake shut the motor off wait 15 min fire it up and let the smokeshow come to life.
GeorgiaBird
never tried sea foam..
but When I do my oil changes, I add lucas to the oil, & use there fuel additive.. seems to work well. but do plan to try the sea foam.. may rotate the two on oil changes..
Xploda
Milton,Wa
2.3 soon to be turbo
Sea foam is good. I heard atf through the vacuum lines works real good too for cleaning shtuff!
Gotta_gofast
Wisconsin
6.0L Powerstroke
I use the 1/3 rule with sea-foam every spring and fall...
