broncogirl
- Dec 31, 2008
- 28
- 1
- PNW
- 88 BII in a 66
- 2.9L
- Suspension Style
- 4wd
I am dumb with electronics, following guides for testing, not seeing this scenario: With fuel pump relay out, jumping the relay connector from 3 brown to 4 yellow, runs the pumps - or at least the high pressure pump on frame - WITHOUT the key in at all. All the testing guides I'm finding say to turn the key to ON for this part of testing, and I'm not seeing mention of pump(s) running with no key. I kept it jumped for about 15 seconds, longer than typical prime, and the frame pump sounds strong and doesn't shut off. Did not get back to tank to listen there, and did not try with key on, nor cranking.
More info: Can't find my pressure gauge at moment. Key on produces some click but no pump hum. Key to crank turns engine over plenty strong but apparently no fuel. Starter fluid spray gets it running, only while that lasts. Have a nicer newer inertia switch, and bypassed it with no change. Newer battery only now down to 12.7, after many start attempts.
- Is it a problem that no key is needed to run pump(s?) when wires 3 and 4 are jumped with no relay in? Does that point to any particular cause of my crank-but-no-start issue? Can't find my fuel pressure gauge at the moment, should I try crank and run it like this?
- Then, tester light fails to light between #1 Tan/lt grn & battery positive when cranking with relay out. Is that a useless test due to jump running with no key, or does that indicate bad EEC, bad connection to EEC, or bad PIP?
