Fuel Pump
wild horse
Puyallup,Washington
Ok so my motor is still on the stock fuel pump and I was woundering if I can use an electric fuel pump insted of the mechanical pump ? I have a Holley blue pump with regulator and I also have a brand new in the box mallory comp pump 110 that I could use. Is it possable and what would I half to do to use the pump on my rig or should I just put a new mechanical pump on ?
3rd Petal
Nevada
Would probably be best to just put a new mechanical fuel pump on, they are cheap and easy to change.
If you already have an electric pump and want to use it, just splice it somewhere in the fuel line, closer to the fuel tank is better. Then use a regulator to dial the pressure down to 5 or 6 psi
