All explorer axles are 31 spline, and they have the spring perches on the bottom side.Anyone know what differences there are between an 8.8 from and explorer and an 8.8 from a full size bronco? Besides the width...
Thanks.All explorer axles are 31 spline, and they have the spring perches on the bottom side.
95+ have disk brakes.
Thanks. Thats what I guessed just wider...both 31 spline. the sploder is more narrow than the bronco/f150
Depends on what year it came out of 78-79 are full size. Early broncos are about the same as a B2.Oh, another ? If I get the dana44 kit from copycat, will it make my front end full width?
This is the route I was going to go at first but found a sweet deal on a HP44 from a 79Bronco.Copycats kit puts a f150 dana44 ttb in the ranger, and yes, it is full width
That would be an easy swap but you will need some fiberglass fenders.See I don't want to do an sas, I want to stick with the ttb and make it a long travel suspension system.
what for?That would be an easy swap but you will need some fiberglass fenders.
What he ^ said. or you could go with NO fenders..The wider axle will necessitate really cutting the fender to clear upward suspension travel and turns while the tire is stuffed into the well. A buddy of mine just put a D44 into his 90 and went with a 3" body lift and 6 or 8 inch lift kit and it still looks like he'll have to trim the fenders. Fiberglass ones are the only way to keep a full fender after going wider, they are flared out a bit to clear bigger tires/suspensions.
