Getting the fuel gauge to work!
NUguy
So I have a 1990 Ranger and a 1990 Bronco II. The fuel gauge in both were inoperative when purchased. I trouble-shot it down to the anti-slosh module and tried a replacement from a 91 ranger but it was bad as well.
I decided to bypass it and while it may change while turning, braking and accelerating it is accurate under steady driving. This is how I fixed it.
Removed the cluster. The anti-slosh module is the board plugged into the right side in the picture:
The anti-slosh module out:
Remove the three connections on the left side. I used pliers to pull them.
The connections removed:
Jump the other two connections. Here I used a wire but later I soldered the pins together on the back side of the board:
This has worked for both of my RBVs and to fix a friends 93 Explorer so I figured the problem is common enough that I should share.
Hope it helps. Also if you don't want to pull the other three connections you can tape over them to test it.
RonD
Interesting, thanks :icon_thumby:
I always thought the aniti-slosh circuit was in the tank
Ranger2300
Two thumbs up! I'll give this a try tomorrow after work.
Ranger2300
Well it may have been problematic, the gauge went from 3/8 to under 1/8 but the tank is still full. Looks like the bed has to come off. The good news is I got to clean up all the grime on the clear plastic cover, and I figured out how a second gen dash comes apart without breaking antyhing!
trikerider
'94
great thread I have a problem w/my '94 since I was in a minor rear-ender. I checked the inertia switch altho doubted it has any bearing on the problem.
I'll check this tomorrow.
