HELP- Break IN - Ignition Lock Body & Housing Damage - need parts-1990 Bronco II
rgg
Need Help- Attempted vehicle theft -
Damage to : Ignition Lock cylinder housing ( broken cast circular flange around Ignition lock cylinder [pieces missing]).
Missing : Ignition lock body (gone- they slam hammered it !)
Need parts !!! Anybody know a source !?!
PLEASE LET ME KNOW if you find a 1989-90 B II and/ Or 1989-94 Ranger in junk yard. AM in serious need of parts.
Vehicle specs: 1990 Ford Bronco II ; 4 X 4; 2.9 L engine ; Automatic trans/ AT; Cruise Control/ CC; Eddie Bauer edition
This is my daily driver. Gotta fix it FAST.
Any help appreciated
Thanks
Richard
14826
alwaysFlOoReD
Blang - not bling
Red Deer, Canada
'91, '93, '98
Various
That looks pretty bad. I don't know much about how those are assembled but there are a few other vehicles that the parts from should fit. Any ranger of the same year should work. And Mazda. Explorer. Maybe Aerostar. Also worth a look are rangers from 83 to 93. I'm not sure if the columns changed or not.
PS; check the date of threads you respond to.
rgg
Thanks for the reply. Much appreciated.
NW Arkansas
Where are you located?
Dennis
rgg
NW Arkansas
I would check with the you pull junk yards and see if they can help you. I do know where there is a 90 BII sitting in a junk yard but it is up here in NW AR 5-6 hour drive for you.
Dennis
rgg
UPDATE: The part I need is :
Ford description: " Lock Cylinder Housing"
Ford OEM part # : E9TZ-3511-D
Make/Model compatible year vehicles
(use the same steering column)
Bronco II - 1989 -1990
Explorer - 1991-1994
Ranger - 1989 - 1994
ANYBODY !!! - PLEASE LET ME KNOW if you find a 1989-90 B II and/ Or 1989-94 Ranger in junk yard. AM in serious need of parts.
Dennis
Hi Dennis.
Could you give me the name, contact # for that junk yard ?! Please. ...can't find anything local.
ANY help appreciated.
Thanks
richardg20657 at gmail dot com
NW Arkansas
rgg
I called the You pull and both the B II's have been crushed. Sorry . They have a yard in Beaumont, TX that you might try, 409-554-0447.
Dennis
rgg
rgg
Dennis
THANKS Dennis. Much appreciated. Will call.
alwaysFlOoReD
Blang - not bling
Red Deer, Canada
'91, '93, '98
Various
Have you tried eBay or Amazon?
