Was out messing in the B2 and it died, i figured the inertia switch was tripped, so my buddy in the passenger seat hit the button and it started up. Well was driving around with him alittle later that day and same thing happened but it was randomly and nothing was tripped. This time he just kicked it around with his feet and she started back up. Got home parked her and now the high pressure pump isn't priming and shes not starting.
-So i jumped the inertia switch but it didn't work.
-Checked the fuel pump and eec relay both are clicking and im assuming working.
I took off the fuel pump relay and jumped power to the high pressure pump and it primed right up and i started her up. The problem with that is the high pressure pump constantly stays running and before as most every B2 owner knows the pump only primes for a acouple seconds then should stop before starting, now its on constantly priming.....i think the ECM is bad but not sure and really dont want to go buy even a used one. Do you guys think it is alright if i just run KEO power to the high pressure pump or will this cause the HP pump to burn out?
