- Jul 24, 2016
- 351
- 40
- 28
- NW Arkansas
- 1990
- 2.9
- Suspension Style
- 4wd
- My credo
- Do what you can with what you have where you are
So I had driven my 1990 BII stock 4ALD Automatic Transmission over to Tulsa, OK yesterday. It was in the mid to upper 90's. Roughly after about 200 miles I noticed something on my rear window. Now I have 3:73 LS gears and was running about 65 MPH. In another 40 miles or so my transmission started to slip. As it turns out it was transmission fluid on the rear window. I was at a place I could pull over and check the Transmission dip stick and nothing. I went and got some mercon transmission fluid and brought it up to the hot level and drove it home another 15 miles without any issue what so ever. It shifted as it should. This morning when I checked the fluid it was where it should be cold and there was nothing on the floor. So is it possible that it was so hot outside that the transmission simply boiled over spewing fluid out the vent? I remember once after the BII had sat for awhile and when driven mud wasps had built a nest over the vent stopping it up and causing transmission fluid to spew out when it got hot.
Thoughts
Dennis
Thoughts
Dennis
