Surrey
- Jan 12, 2011
- Vancouver, Canada
- 1989
- 2.9
Alright I figured its about time to introduce the truck, and start a build thread.
I started with a 1988 Bronco II, bought for $500 in May 2009. Wheeled it a few times, but the clutch was going out, and I blew it quickly... Also destroyed a hanger, which in turn blew out the back two body mounts when the suspension started resting on the bottom of the body. Spent $300 on some mediocre used 31" tires.
Finally have the funds to fix it up back in January, and so I start looking at putting a body lift on it, and realize both rear body mounts were absolutely trashed. Had blown holes in the rusting frame. As I have no experience in welding, and the truck already needed a new clutch, I said F*** it, replacing the truck.
So I have replaced the truck. Another $500 Bronco II. This time its a 1989. Its from America, and has a 5-digit speedo so I really have no idea how far it has traveled, but it reads 14xxx miles.
The interior is immaculate. The frame is also in immaculate shape. The only place there is any rust is at the back edge of the front fenders, where the running boards meet the wheel well. The tranny is in rough shape, stupid auto, but my girlfriend needs to learn to drive, so sadly even if I replace that it will stay an auto... And the engine and exhaust both could use a bit of work, but for $500 Im still very excited.
Right now, I am busy tearing apart the old truck at a friends house, in his carport. I have pulled the whole top of the engine apart, as well as stripped the other useful crap out from under the hood (power steering, alternator, ect) Somebody stole the radiator and tranny cooler that was leaning against the fence... That pissed me off, even though I didn't have any plan for them.
The whole back axle has been ripped out, and the front axle is held in with only the axle pivot bolts right now... Almost there. After that, I have to rip the doors off, pull the driveshafts, and then get the scrap hauled away...
And then the building begins!
This Saturday, I am going out to the wrecker in search of Explorer coils, and some Ranger 4x4 blocks.
Although both sets of axles are the same, d28 and 7.5", the old truck has 4.10 gears, new one is 3.73... So my plan is to rebuild the axles I have out of the old truck, weld the back, and then putting them under the new truck when I replace the leafs and get drop brackets.
So the current plan is to put the explorer coils and ranger blocks in immediately, so my 31s will fit again, and run her like that for a bit. (not trimming the fenders on this one, at least not til shes been beat up some.) Got to rip out the sway bars too... Once I have the axles rebuilt, and money for drop brackets I will be looking at getting custom radius arms and probably new tranny crossmember/rad arm mounts. I can't weld, but friends can, and I plan on learning when I can afford a welder (two friends are welders by trade) At that point I will also put in explorer leafs and belltech 6400 shackles, maybe add-a-leafs too. Will also be putting in EB 3.5" lift springs probably... Maybe some jeep coils... Not really sure yet.
Right now, I am faced with the problem of naming my truck. Im completely stumped. I want something that says 4x4 truck, but "the Bronco" is just weak... Any ideas? Thanks.
