88Bronco2EB
- Oct 9, 2009
- 81
- 2
- 1988
St. Louis County
there are better ways of wording your questions without being sooo condecending....i just have two ?'s for you
why did you reuse the d28 all the brand new parts and use a piece of shit for a front axle and the second why the hell if you are lifting it would you reuse the auto hubs they suck please change them at least
lol, I'm low on money!!!!! Don't worry they will be changed later for sure!!i just have two ?'s for you
Yes, I have 3.73s. Its not that bad. You definitely know the 31s are there, acceleration is not as great as before. I have yet to go on the highway yet so I'm not sure how it will do in OD, but all in all not that bad.damn, that thing looks good, got a question tho, what gears are you running? stock 3.73's? i'm putting 31's on mine and i have 3.73's, and i wanna know if the 2.9 and stock gears have trouble with the bigger tires.
Yeah I think 4.10s will be perfect for you. I saw in your build that you have a manual so even with the 3.73s you wont be to bad. I plan on putting the K&N back in. I'm going to try and find a place I can get some aluminum sheet metal an build a heat shield then I'll open the exhaust up a bit with a Thrush welded muffler, then look into getting some pacesetter headers. How do you like your set??ok cool, i was a little worried about it
yeah, i wanna regear too, i'm just going to 4.10's tho, i think 4.56's would be overkill. once you put the k&n filter back on, you should have a little better acceleration. i've had one on mine for last 7 or 8 years and acceleration is WAY better than it was with the stock box
i havent had a chance to run them yet, i just put the engine back in yesterday morning. i hope to try starting it in a couple weeks, i gotta do some other stuff first. i didnt have any clearance issues with the block or the oil filter mount....i did have to remove the driver side manifold to get the engine back in, it kept hitting the frame.Yeah I think 4.10s will be perfect for you. I saw in your build that you have a manual so even with the 3.73s you wont be to bad. I plan on putting the K&N back in. I'm going to try and find a place I can get some aluminum sheet metal an build a heat shield then I'll open the exhaust up a bit with a Thrush welded muffler, then look into getting some pacesetter headers. How do you like your set??
Thanks man,Hey that is looking good, very clean BII!
how is the lift, i kinda want to lift mine more but i am short on funds.
