My build thread
Harley
Oregon
How did you fix the striker pin for the back hatch? I'm having the same troubles
i found a bushing that was the same outer diameter as the sleeve thing on the other striker and drilled it out to fit the pin....worked great...i used a plastic type of bushing hoping it would be a little more quiet.
shadow88
CLOQUET MN
I'm using the same pitman arm as you the fa600, is you drag link touching your outer left tie rod?
Harley
Oregon
No...it's real close though
Sent from my SM-N900P using Tapatalk
shadow88
CLOQUET MN
If you can take a pic, I'm thinking I might have to do something different
Harley
Oregon
How much lift do you have? Maybe you need the 400 arm?
1RangerNut
Central,IL
2.9L
My steering is real close to touching also with a 4" lift.
shadow88
CLOQUET MN
Mine is touching, it's rubbed it to clean metal
shadow88
CLOQUET MN
Ranger nut what pitman arm are u using?
Harley
Oregon
finally got that nasty muffler replaced, now it sounds good! next weekend if its nice, im going to rip out the interior and clean the carpets and redo the headliner...looking forward to that...
smccrory60
Dillon, CO
2.8 V6
I should have my new headliner material later this week. I'll let you know how installing it goes!
Harley
Oregon
Cool..I'll be looking forward to hearing how it went...
Beachbuggy
Charlotte, NC
I did mine for the first time recently, my suggestions:
1. Glue, lots of glue
2. Go slow
3. Glue, lots of glue
smccrory60
Dillon, CO
2.8 V6
Hopefully 2 cans of adhesive is enough. Got 2.5 yds. of fabric and the glue on that auction site for $62.
Harley
Oregon
What site did you get it from?
