need help again
a88b2on38s
McLeansville, NC
last night when i got home from a fourwheeling trip i parked the bronco like i always do. then this morning i went out to crap it and nothing..so i check the fuel pump interia switch its good..the relays click on the off. fuse is good the ground on the battery is good..so i unplugged the fuel pump in the tank and tested it with a test light, it has 3 grounds and a power that blinks off and on. i also have hot wired it at pumps the when i turn the key switch on i hear nothing but the tank click..was wondering what could cause this..any help is much apprieciated.thankx:icon_confused:
Cyberbeer
Spotsylvania, VA
Lemme make sure I understand you correctly. You tested the in tank pump and it works. You turn the key and you hear it whir? Do you hear the rail pump? If not, then its likely the relay, or the pump its self is dead. The rail or high pressure pump is tucked into the frame rail under the drivers side door. Maybe a wire broke, that happened to me once.
