dantai
- Sep 11, 2015
- 2
- 1989 + 1986
Hey fellow Bronco lovers,
I am new to this forum and am hoping you can solve my month-long battle with my bronco ii. I write to you today in desperate need of some help with a problem I can't figure out for the life of me.
I recently bought a 1986 Bronco ii 5speed manual 4X4 with the Toyo Koygo TK5 transmission.
The O-ring in the clutch line intake port was busted so I figured I would just change the clutch, flywheel, and release bearing.
Everything came out and went in fine and I didn't seem to have to much trouble. When I fire it up and put it in gear and release the clutch you can hear a hissing (the clutch plate slipping I assume) and I am barely propelled forward. The engine would rev and sound proper but I could barely get going.
At first I thought the plate was just covered in brake fluid from popping the hose off the bleeder screw. Then I thought maybe I didn't put the throwout bearing on properly. Then I thought there was an airlock so I bled it about 10 times (vaccum, bench bleed, gravity bleed) and nothing has worked. I had a mobile mechanic come check it out and he said it is likely a defective pressure plate. I tore it out after he left and the pressure plate looks completely fine. All the forks are straight and lined up.
I have pulled that tranny out 3 times now and the onnnnnnly thing I think might still be the problem is maybe my slave cylinder is pooped. I was able to suck bubbles out of the bleeder valve when it was closed with the vaccum pump. I don't know if that's normal or not. It's $180 bucks so I don't want to spend money on it if I don't have to.
Please if you have seen this problem, or have an idea as to what I can do next to determine the issue let me know. I need this puppy running before the snow flies.
Thank you and happy Broncoing :icon_thumby:
