New poster looking for opinions...
windsordeath
Jay,FL
Hey guys, Havent posted much on this forum..just do alot of reading...after messing around with mustangs for so long, I wanted to get back to offroading with as much rain as we've been "enjoying" here on the gulfcoast...I have a 84 BII 2.8L 4SPD and That is my mudder...stone stock for the time but I want to get it squared up...I got it out of the bushes today and aired up the tires, then drove it on the lift and started looking everything over...after staring at all the oil leaks and exhaust leaks, not to mention the complete lack of freeze plug on the driver side...it occured to me I might not want to continue to pour oil into this engine on a weekly basis...So my question is can I do a full rebuild on this engine without killing the wallet or should I not waste my time and try to find something to swap in there?...if rebuilding it who has a master kit that isn't insanely priced?....any elp appreciated...
Mutant Pony
Hersey, Mi
Well, I wouldn't mess with the 2.8 if it were me.
I ran one and it sold me on Rangers, I've had one ever since. The 2.8 is an ok motor at best. It would be cheaper to install a used 302 than to fix the 2.8. It has been done MANY times and all the tech is right here on TRS.
A 4.0 is also an option, it will bolt right in place but, requires a whole different fuel system, wiring and computer.
ANY motor can go in there, were there is a will, there is a way. The two above would be the most sensible ones.
windsordeath
Jay,FL
I assumed so...I have a complete 90 STX with 4.0 5spd I'd love to swap the powertrain from...But it belongs to a customer that wont pay his bill so I do and don't own it....I have 302's for days but I kinda want to keep the weight down a little....well..Where can I find those transcase adapters for t-5's? a s-10 4wd?
Mutant Pony
Hersey, Mi
I agree with you there. Although I have a v-8 Ranger, I prefer my 3.0. It airs out really nice. The v-8 truck is really nose heavy.
You would have to build a custom T5, front half Ford, back half chevy. Then use the s10 transfer case.
windsordeath
Jay,FL
It's definitely not a daily for me....it's a trail only truck/also for getting to the hard to reach swimming holes...there's no real way i could compensate for the additional weight could i?
85_Ranger4x4
December 2013 OTOTM
SW Iowa
I like my little 2.8, if I had a manual transmission I would be looking for another used one in a heartbeat. But as much as I like it, I wouldn't rebuild one... like Mutant Pony said it would be nearly the same $$ to rebuild a V-8 as it would be to rebuild a 2.8 (or any other V-6 for that matter), and I am not putting a healthier engine onto my time bomb A4LD, so while I am changing both... I am going V-8, 289 with a C-5 to be exact.
I don't know what kind of power my 2.8 is putting out but it can't be good, and it has enough to get the job done with my setup and needs.
If you go EFI a 4.0 would the way to go, and having the entire donar vehicle handy would be a plus as the entire fuel system is different from carburator to EFI. I wouldn't mess with a 3.0 but that is just me.:icon_twisted:
Any other engine aside from maybe the 2.9 would need a different tranny, the 4spds were not all that strong without hanging a 4.0 on the front. The neither the 2.3 or 3.0 will bolt up to it, and the 4.0 would shred it.
A 302 is only about 150lbs more than a typical V-6, not really that earthshattering. If weight is your thing and you are willing to get creative, Black P-38 is putting an aluminum V-8 into his Ranger, it is in the V-8 swap forum. It is actually lighter than his 2.3.
ammocj
You don't need to rebuild the engine to fix oil and exhaust leaks. Or Freeze plugs.
Fix those,adjust the valves and run that motor till it quits.
Al
85_Ranger4x4
December 2013 OTOTM
SW Iowa
Al
Depends on what the story is on the freeze plug. If it deteriorated with age and blew out on the way to the shop is much different than if it froze while it was sitting there and busted other things too.
enginepaul
Northern California
A rebuild isn't always necessary. These engines seem to go forever with minimum care. I did an overhaul on one of mine that turned out great. I needed new cam bearings so I replaced the cam, even though it was still good - I just wanted a little safety there as long as I had it apart. I just reamed the ridge, had the pistons expanded, new rings and bearings and rebuild heads. Ran like new until I sold that one.
Those seals can be removed and replaced without removing the engine; the freeze plug may be due to plain rust.
windsordeath
Jay,FL
Freeze plug has just rusted through and I am expecting more along the way....when I say oil leaks, I mean the enitre engine is leaking along with the characteristic valve seals so If i were fix the leaks It would only be wise to pull the engine...And if i were to go through the trouble then I would rebuild it...In the end then what would I have..... same power and possibly more money involved...I'd like power to imporve and weight to be kept down but I'm thinking seriously about that 302 swap....I have a donor fullsize bronco along with mustang mounts and oilpans...I'm thinking in this instance it would beasier money wise to do it this way...
windsordeath
Jay,FL
Just a thing to add........To it's credit, that motor starts everytime I put a battery in the truck....and it runs like a top....just has a lot of oil leaks...
85_Ranger4x4
December 2013 OTOTM
SW Iowa
I would just put gaskets, freeze plugs and seals in it and run it until it drops then.
But that is just me though.:3gears:
windsordeath
Jay,FL
Damn this is hard!....ok folks appreciate the opinions...I just got to think on this longer...
Mutant Pony
Hersey, Mi
I would have to agree, if the motor runs good, the cylinders are probably in good shape, Maybe run a leakdown or just a simple compression test to help you make your decision.
I would run a compression test and if all cylinders were 120 or more, I would just fix the motor.
