- Aug 6, 2007
- Aurora Colorado
- 88,89,90,92,93
- FORD
- 2.3,2.9 and 4.0
are those parts painted purple?
I assume you used weldable primer so you don't have to grind the primer down again?painting the center section before installing the third leaving the outsides primer till the spring perches, shock mounts, and brake calipers are welded on
I hope to get a ton of work done this weekend.....i FINALLY have a Saturday off from work.
Is it with the USA Standard gearset or the Yukons?I cannot get the D44 gears installed with a good pattern...this thing is kicking my ass. I have gone through all kinds of shims, moving them around, taking the pinion in/out and replacing shims..........I am starting to wonder if the i do not have a housing problem.....
I have another D44 housing at the house i think, i might just grab that and start over....
i jsut can't find the right combo of shim locations to get it right, just frushstratingIs it with the USA Standard gearset or the Yukons?
