i was going to extend them, put joints on the end, tube inserts, tube, new crossmember.
at the same time i was going to push the front axle out 2"s, which ment new coil buckets, shock mounts, and steering geo., and a trac bar mount.
I already have the leafs, already have the flat top knuckles, steel to build leaf mounts, and already have shackles. That just leaves me to buy the steering set-up. And with the springs i am using the clamp hole is offset so putting the leafs in place pushs the front 2" further forward then stock location.
