just a shot from the front
Its 1-1/4" Sch 40 A500 grade B, so thats 1.66" OD with a 0.140" wall, which is stronger than the usual mild steel HREW 1-5/8" 0.120" wall that most people use.Were you using pipe or tubing in that bender?
i spent quite a bit of time playing with the bender useing used pipe to get to a point to where i could make the bends with no kinks and no dimples in the pipe. Once i got the hang of it i went and bought the new stuff and started the cage. I was happy with the bends, i don't have a single dimple or kink in any of the pipes.I think the cage looks great, especially using the HF bender. keep up the good work and I'm sure you'll find a way to make it turn out the way you plan.
i played with the roller settings on the bender till i found just the right spot for the pipe i was using. And the type of pipe i used....they make a few different types of pipes in that size that vary in strength and construction.....thats why i was so anal about what kind of pipe i bought. I had to call several places in my area before i found the pipe i wanted.I used sch40 when I made my doors and didn't have problems with kinking, it just flattened out the corners. whats your secret? did you fill the pipe before bending?
So what's the secret? RBi spent quite a bit of time playing with the bender useing used pipe to get to a point to where i could make the bends with no kinks and no dimples in the pipe. Once i got the hang of it i went and bought the new stuff and started the cage. I was happy with the bends, i don't have a single dimple or kink in any of the pipes.
Ah yes, I see I'm not the only one who has had that conversation with the Mrs.Wife came out to see progress and wanted to know why i can't help keep the house as clean and picked up as i do the garage lol.
CA$H in hand if you can send one this way.. when there done! im in canada. let me know when they become available. -CTyeah the doubler may find its way into the B2, right now all my bits and peices are off at a buddies race shop, hes looking into building one peice shafts for it and others.
I have been saying for years that I'm going to either coil the front or reverse shackle it. She only has two leafs but they are flat and like 5/8" thick and they don't move. Yours look much more compliant. RB
