Well... that is an interesting question. You could blow whatever is clogging the oil passages down further into the block, potentially clogging something else - like the oil pump pickup screen. You could also try vacuuming it out or just picking it out with tweezers if you can, but you might not get all of it. You basically have the choice between causing major damage to the bottom end of your engine because it will starve for oil if you do nothing, or potentially causing major damage to all of your engine if something else is clogged.
The best way to fix it is to tear the engine down and clean it ALL out but I don't know if that is a realistic option in your situation.
If anybody has better ideas feel free to post them...
