winkeldc
- Aug 23, 2018
- 5
- 1
- 3
- 1990
My wife recently bought a '90 4x4 in relatively decent shape. I have been trying to get the driver's side door lock working, the door wouldn't lock with the power locks or manually. The actuator is broken. I disconnected the actuator from the mounting bracket and I could lock the door, but then it wouldn't unlock manually. When I hold the handle rod up, the lock works perfectly so there needs to be tension on that rod and/or the exterior handle.
Is that tension provided by the actuator or is there a spring or clip that holds the rod or the exterior handle where it needs to be? With the actuator disconnected, the exterior handle is loose, but the interior works as expected. I have looked everywhere so I think I may need some help from those with more experience.
Second question. How do you remove the actuator? I have it disconnected from the mounting bracket, but I can't move it enough to get the top shepards crook removed from the plastic connection that ties the actuator into the rest of rod mechanism. Is there a trick to this?
