Question about Starter
BIIHawg
December OTOTM Winner
Prince George
I'm doin a 4.0L swap into my bronco II. I just need to know what each of the hook up points on the starter are supposed to be connected to. I know the larger one is for the power wire. What is the smaller nut for and also the male connector.
Any help is much appreciated.
rickcdewitt
nor-cal
4-0 swap
large wire goes to the constant power side of the relay.run a smaller wire from the spade connector to the hot in start side of the relay.done!
BIIHawg
Prince George
That explains 2 of the connections. What is the second smaller nut for? Or do I not need it?
sweetsride
Terrace B.C.
2.9l
hey, i just put a 4.0l clutch in my B2, and had to wire up a 4.0l started, do what rickcdewitt said, the other post witht the nut is not used
Later
Kris
BIIHawg
Prince George
Thanks guys. Got her all in and wired. Works fine.
