markhm2
- Sep 23, 2013
- 3
- 1
- 3
- 89
- ford
so i went thru the rear brakes, lines (made sure they got fluid thru them ) , removed completely the inline abs module and all and the culprit was the master cylinder and rear center brake line above the rearend differential. It was clogged shut. THE MASTER CYLINDER CAUSES ALL THESE PROBLEMS because it loses the seals in rear brake half to the rear brakes per ford (bad design) and no pressure to back brakes causes lines and wheel cylinders to clog from no pressure. So I put on new master cylinder, removed the hydraulic abs block from line and replaced with straight brake line
( female 7/16-24 thread, both ends 6" lg ) , bought new rear center line, rebuilt wheel cylinders and all is working good after 9 years of trying ! HALLELUYA !!!
New parts and master cylinder about 65.00 total !
