rear lift
1986b2
what is the cheapest way to lift the rear of my b II 1-2"????
ThatGuy
Oak Ridge, TN
Have a friend pick up on the bumper
pangborn83
on a more permanent note, I'd say shackles are a cheaper alternative.
The Jester Race
ΜΟΛΩΝ ΛΑΒ&
Sacramento, Kalifornia
Ford, BMW
:icon_rofl: Thats great.
1986b2, check your PM's. And this is like the 5th or 6th thread you posted about lifting your truck. You can post multiple questions in the same thread, no need to make a new thread for every new question basically asking the same thing as your other threads.:icon_thumby:
-Jester
ThatGuy
Oak Ridge, TN
Ok......or shackles.
1986b2
jester i know ive posted alot of new post but it seems to get everyones attension better to post a new one:icon_thumby: and what are the best and cheapest shackles? also do exploror leaf springs bolt up to stock b2 parts?
ThatGuy
Oak Ridge, TN
Go to your local parts store and tell them you want to lower your 90 chevy truck. They will hook you up with some shackles and you take them bad boys home and throw em under your B2
greasemonkey6886
Sulphur Springs, Tx.
The tech library has all the info you need as far as swapping sploder springs into you BII. Not hard at all and I will be doing it in the not so far off future myself.
Paul
trail B2
North Eastern Ca.
I prefer putting a block out of a ranger in it if you trying to help your 4x4 ability.Explorer springs are kinda stiff for the front or back IMHO.
RacinNdrummin
Auburn, Wa
Not really at all... If you ask me, they are perfect for a B2.
1986b2
@ trail B2 are you talking about stock ranger leaf blocks? and what year rangers?
LIMA BEAN
ALASKA
Belltech 6400 shackles will do on the cheap.
Shran
Rapid City SD
Belltech shackles will get you around 2", Explorer (4 door) springs will get you another 1-2, and then add your choice of blocks.
Posting a crap ton of threads is rude and it won't get you more answers...FYI... I know you think it will but people will catch on.
Eagle Point OR
2.9l FI, 2.9L FI, 2.8L
Shackles change pinion angle. blocks create play. springs are not cheap....
Rock the blocks if your stock. if you have a 4-6" lift, using shackles will change the pinion angle enough to help with driveshaft angle. but springs.... springs are the way to go.
Edit: I would use explorer leafs if all your after is 1"-2" they ride like add-a-leafs, but! wont sag so much when you pulling your dirtbike,quad,load of dog $#!t....ect.....
