NETX_S4
- Feb 13, 2023
- 12
- 3
- 3
- 1988
- Bronco 2
I'm about midway through rebuilding a 2.9 from an 88 B2 that seized from rust in the cylinders after being parked for about 8 years.
There is some surface rust on some of the rocker arms. Can I clean up the rust, make sure all the contact points are clean and smooth, and reuse them, or do they have to be replaced?
Also is a special tool needed to pull pull apart the rocker arm assembly? It looks like there is just a pin and clip on the end, and springs between the rockers, but I'm not sure how much tension it's under. I didn't want it to all come flying apart when I pulled the pin.
Thank you!
Thank you!
