The_Dealer
- Jun 12, 2010
- 167
- 5
- Macon, GA
- 1985
- Duh!
Ok, everyone yall remember the write up i did a while back about installing aal's? Well im doing a write up on dropping the coils buckets 1.5" for about 2.25" of lift. Its pretty simple to do, its just time consuming. The hardest part is figuring out how you are going to do it, but I did that part for u guys.
Aight so heres the part where i say do this at your own risk, and if u **** your rig up dont bitch at me. and use jackstands.
this write up also doubles as spring removal if u've never done it
Aight so this is the part where u have your rig jacked up and the tire and wheel off.
Heres some pics of my starting measurements, yours will vary. I already had about 2" worth of spacers so Im shooting for 4" with 2.5" pivot drops and camber bushings(ill show yall how to install those next week). The light was messing with me so i took a couple pics if u cant see it too well
If u cant read it its 33.5"
first thing u need to do is remove the shock by removing the upper nuts and bushings.
Next remove your coil spring upper retainer(if equipped, mine are just some small u bolts from lowes)
Then remove the sway bar nut and bolt. U dont have to remove the whole link or anything
Now remove the lower shock bolt and remove
For some reason my camera didnt save the next few pics, but ill post some up tomorrow when i do the passenger side.
Remove the lower spring retainer nut and washer with a 1 1/8" wrench. If u dont have one, u can use a pair of vice grips, thats the way i always do it.
Now twist the coil and pull it out of the upper ears.
Ok, you will see 3 rivets on the spring bucket, then theres a bolt at the front under the frame, and a rivet at the back under the frame. Remove the bolt and grind the rivet heads off. Be careful with the rear one its close to the brake line. Now after you have ground the heads off hit them with a punch and knock them out. the bottom rivet was in there pretty good, i think because it goes to the engine xmember as well, so i ended up drilling it out. i couldnt get enough room to hit it hard enough. heres the coil bucket removed
Now im gonna go ahead and warn you. the brake hard line is mounted to the coil bucket and it meets the hose. you dont have to remove the hose if u are careful. theres plenty of hard line to move the bucket out of the way as long as u remove it from the plastic clip on the frame.
So the way i did it was i took a 4ft section of 3/4" square tube and cut it the length of the bottom of the coil buckt. I cut 2 pieces and stacked them and clamped them to the bottom lip of the bucket, and drill my holes through them. Then i mounted the 2 pieces of 3/4" between the bottom of the frame and lip on the coil bucket. It acts as a spacer 1.5" spacer which should net about 2.25" of lift. I ran some bolts through the bottom of the bucket, 3/4" spacers, and frame and ran the bolts tight. Doing it this way puts the buckets in the stock location and makes sure it stays in the stock position(front to back) then i drilled holes through the bucket and framerails and run my bolts in, roughly the same places as stock.
Now i ran into a problem on the passenger side. the pivot drop goes on top of the bucket, but with the bolt out it gave me enough room to get the bucket out. so when i lower it what im going to do is notch the bottom 3/4" tube to clear the 1/4" lip from the pivot point. that way the bucket sits flat just like stock and isnt angled funny. Again not too hard to do, i just ran out of light so i stopped for the night. I will get some pics up tomorrow of how i actually mounted the buckets, and measurements of the finished product. It looks as if i got about 2.25" on the drivers side, and the passenger side is unfinished.
The good thing about this mod is u can get around 2" lift for the price of a grinding disk and some bolts. it also allows u to keep your shocks you are currently running. Going from the looks of it, i wouldnt drop them more then the 1.5" that i did because the bucket will want to cock out any further down, and u run out of room to drill thru to put the mounting bolts
enjoy and happy wrenching
