shadow88 Member Joined Sep 7, 2011 Messages 309 Reaction score 1 Points 18 Location CLOQUET MN Vehicle Year 1990 Vehicle FORD Engine Size 4.0 Sep 11, 2011 #1 Is there a fuse for the temp gauge? New sensor and still not working
BRUTUS_T_HOG New member Article Contributor Joined Aug 26, 2008 Messages 0 Reaction score 2 Points 0 Location Rainier, OR Vehicle Year 89 Vehicle Ford Engine Size 2.3L Sep 11, 2011 #2 you replaced the 1 wire sensor and not the 2 wire sensor correct? ground the 1 wire sensor wire and see if the gauge pegs. the 2 wire sensor is for the ECU and the 1 wire sensor is for the gauge and the 1 wire sensor is actually called the sending unit
shadow88 Member Joined Sep 7, 2011 Messages 309 Reaction score 1 Points 18 Location CLOQUET MN Vehicle Year 1990 Vehicle FORD Engine Size 4.0 Sep 12, 2011 #3 I replaced the sending unit , I even tried a different gauge cluster , both are doing the same thing, oil and temp not working
