so you're saying that if i fill my tires to 35psi, with the tires cold when it's -30, then drive down the highway, the heat from my tires turning are going to bump the pressure up past the, most likely 3:1 safety factor, minimum, and blow the tire out?
what if i don't let the air out of my tires when we go into summer? i mean, calgary gets to -40 in the winter, and 35 in the summer is not uncommon, the change of 75* in 6 months isn't going to cause this though?
how about when calgary has a chinook, which normally causes temperatures to change by 10 degrees per hour, and again, not uncommon for it to change by 15-20 degrees... would that cause my tires to pop?
(temperatures in celcius)
