Transmission Issue
Ryan_D85
SE Kansas
Okay I need some help!!! Took my trans out of my 1985 Bronco II it has the FM145. Put in new clutch, pressure plate, and throwout bering also put in flywheel while I was at it. Bleed the clutch down and put in new shifter now it acts like it is always in a gear and you can only shift into fifth and reverse. Have no clue what's wrong or how to fix this issue please help need this for daily driving :icon_confused:
PetesPonies
east coast
Did you install the clutch disc with the correct side against the flywheel?
Ryan_D85
SE Kansas
yes I am sure of that paid very close attention when it was reinstalled.
PetesPonies
east coast
Well that will cause the clutch to not disengage and you will have difficulty shifting.
Ryan_D85
SE Kansas
Can u over torque the pressure plate. I am going to pull the tranny back down tonight was just curious if I needed to check that.
PetesPonies
east coast
No. If you over torque the bolts, you could snap them. But the plates fits tightly against the flywheel where it bolts.
Ryan_D85
SE Kansas
Thanks for all the help turns out that a shift fork had popped in when the shifter broke. took the top plate off the tranny and popped it back it to place now it shifts fine.
