removebe4flight
- Apr 26, 2016
- 23
- 1988
So, I am transferring across the country and was about to make the drive. So, I changed the oil, changed the transmission oil cooler to a bigger one and then did the sea-foam treatment through the vacuum line off the brake booster and PCV valve. I let it set for 10 mins and then when for a drive to warm everything up and then check fluid levels. I Got 10 miles and turned in to a gas station to turn around and the truck died. The check engine light is on now and doesn't go out. I had the cruise control on the whole drive. Tried to start it, the engine turns just doesn't crank. The fuel pump clicks on, I check the fuel rail and there is pressure. I pulled a plug and it looks clean and dry. I got it towed home. and now it sits.
Any thoughts on what it could be. I am leaving Tuesday. but I think I am just going to ship it now and fly home. But still would like for it to run before I leave.
