Twister 85 B2 Build
Twister
Omaha, Ne
Duh
2.8L, 2.9L
FML, that's not suppose to happen.
Sent from my SPH-L900 using Tapatalk
dangerranger83
Lafayette, IN
5.0 HO carbed with an np435 and np208
What exactly happened, other then the oil pump rod is out of the engine?
Sent from my rooted SPH-D710 using Tapatalk 2
Twister
Omaha, Ne
Duh
2.8L, 2.9L
That lol, never had that happen and was not expecting it.
dangerranger83
Lafayette, IN
Usually it goes to far down and won't allow the dizzy to be able to turn the oil pump.
What to do now I'm not exactly sure. If the top holder thing is there that keeps it from gong into the pan then you are good (if not no biggy get one). It's trail and error to set the depth of the rod but once in, you are good.
Twister
Omaha, Ne
Duh
2.8L, 2.9L
Got it back in along with the dizzy.
dangerranger83
Lafayette, IN
And???
Twister
Omaha, Ne
Duh
2.8L, 2.9L
And???
Waste of damn time. Still didn't start, got the dizzy in near where it suppose to go according to the cap, maybe a little to the driver side. Got it put all back together. Tried both firing orders, using the spot on the cap labeled one and the one to the right of it. Still all I get is backfiring :(
dangerranger83
Lafayette, IN
Take the cap off and see if the rotor is turning.
Rowdy Fitzgerald
Firefighter
EMT / Paramedic
Squaw Valley, Ca
Double check your firing order and make sure it's set counter clock wise. If that doesn't work the the only thing I can figure it could be is your timing chain is off by a tooth.
dangerranger83
Lafayette, IN
Hard to be off a tooth since the sprockets are keyed and marked.
Rowdy Fitzgerald
Firefighter
EMT / Paramedic
Squaw Valley, Ca
Twister- if you don't mind describe to us how you're setting it on TDC.
Twister
Omaha, Ne
Duh
2.8L, 2.9L
I use kind of a modified finger over the spark plug whole idea. I have a compression tester tube with not valve in it, screwed into the spark plug hole. Attached to that a small piece of clear tube submerged in motor oil. I rotate the engine (clockwise) till air is being pushed into the motor oil, i turn it tell it stops producing air bubbles. At that point it is nearly on the TDC mark on the balancer, so i line it up exactly on TDC and go from there. I used this way on my 2.8 and 2.9 with success on both.
Rowdy Fitzgerald
Firefighter
EMT / Paramedic
Squaw Valley, Ca
Try this. Get it to what you think is tdc. Pull your tool out, stick a Philips head screw driver in the plug hole until it's resting on the piston. Turn the crank with a breaker bar and get the piston at it's absolute highest point. Be careful not to let the screwdriver bind up and damage the plug hole threads. Then set your distributor on the #1 plug wire.
85_Ranger4x4
December 2013 OTOTM
SW Iowa
Have you confirmed you are still getting oil pressure when you crank it?
Without the clip in the right spot that driveshaft will just drop out the bottom of the dizzy into never never land.
Twister
Omaha, Ne
Duh
2.8L, 2.9L
My pressure gauge hasn't read anything since I started trying to start it. I am going to take the dizzy put again tonight and take the electric drill to it and see if I can get some pressure on the gauge.
dangerranger83
Lafayette, IN
My gets pressure while cranking, I can get up to 20psi on a cold start in the summer. In the winter, it takes awhile to get up to full pressure on a cold start.
Twister
Omaha, Ne
Duh
2.8L, 2.9L
Got the dizzy back out and took a drill to the oil pump. Got just a little 40 out of it.
dangerranger83
Lafayette, IN
Your good then.
