vacuum module?
baddmove
Pullman,WA
on a B II.89.AT....where is it located?? i think mine is going out as the truck has to warm up for it to shift into drive.. just started doing this the other day..i did a fluid/filter change and used Lucas, but it still takes about 5 mins before it will shift into drive..i am running in second gear until it does go into drive....
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
Farmington Il.
Passenger side under a cover next to the catalytic convertor. Them are fum.
baddmove
Pullman,WA
what do you mean "under a cover" is there a cover on the tranny? or on the floorboard?
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
Farmington Il.
Should be a cover more like a shield on the passenger side of the trans somewhat shielding it from the heat of the cats. Under that cover/shield will be your modulator for your transmission.
kevinsranger
edison nj
mine didnt have a shield but its in that spot above the cat, good luck if you dont have a body lift
Xploda
Milton,Wa
2.3 soon to be turbo
Its easy once you have the cover off google image the modulator on a tranny and then u can tell where to look. prolly take ya 20 mins :p
