what wires do i need?
roughranger
ok i put points in my 2.8 bronco mud truck, i want to still use the original ignition switch, there is no longer a wiring harness under the hood. what wires/ color of wires do i need to make it start and run? also i want to rewire some parking lights, and interior dome light so what what wires in the switch do i need? thanks rough
enginepaul
Northern California
This isn't a question that can be easily answered. You may want to start with a wiring diagram and some basic wiring skills or information. For instance, the ignition switch as two positions that feed current to the coil; usually 12V for starting and about 9V for running that may need a resistor in the circuit. Try the tech library here and maybe some other sites.
