1BadRS
If you have seen any of my other posts I am in the process of putting my 84 bronco ii back together. The motor is back in the truck and I'm wiring everything up right now for the duraspark conversion.
Here is my question. I have everything wired up except for the (+) positive side of the coil and the red wire on my duraspark box. The previous owner cut up the engine harness so this is the one wire I am not sure which one to use. The bundle of wires on driver side firewall has a bunch of wires that get power when the ignition switch is in the run position but do not get power when in the start position. Don't those wires need power in both run and start? Everything else is good to go.
Thanks,
Thanks,
