redneckfordf2502002
- May 18, 2012
- 83
- In the backwoods of AZ
- 1984 1994
- 2.8L V6 4.0L V6
Ok today I was driving my dad's 84 Bronco 2 4x4 2.8L V6 Toyo Koygo 5 speed manual transmission and I backed up and made the wrong turn. I pulled back up and backed up again the right way. But right before I pulled back up the rear end started acting almost like it was locking up but it still would move just had to give it alot more gas and less clutch. Then when backing up I got maybe 10-12 feet and it just dead stopped. I tried every gear 1st, 2nd, 3rd, 4th, and OD even Reverse. I put it in 4 wheel drive both High and low and checked all the gears and nothing moved (yes hubs were locked). Because it wouldn't move with the it in 4wheel drive I figure the rear end must not be the problem. But my dad says the clutch was going out so I think it may be the clutch but not sure. I was able to put it in neutral and get it back up front. What do you all think it may be?
Trav
Trav
