jkufen
- Mar 29, 2012
- 490
- 1
- Charleston, SC
- 1986, 1991
- 2.9, 4.0
I am having issues with my 91 ranger's ac. There is no power at the plug for the blower motor or resistor. There is power at the fan switch on the panel. If I put my ohm meter from the blower motor to the fan switch I get a positive reading so that tells me everything in that circuit is good. Anyways is there another blower relay located somewhere on the truck that I could check? I know I read somewhere that there isn't a relay from like 83-90 but I am not sure about 91. I have checked all of the fuses and everything is good so I can't figure out why there isn't power going from in the cab to under the hood. I also used the ohm meter to check the fan switch just in case it wasn't relaying the circuit and the switch came back functional. Any ideas where an issue could be? Everything seems good but I can't follow the wiring harness very far.
